Ir para o conteúdo principal
Dymo LabelManager 280 Rear Case Replacement
O que você precisa
  1. Dymo LabelManager 280 Rear Case Replacement, Rear Case: passo 1, imagem 1 %32 Dymo LabelManager 280 Rear Case Replacement, Rear Case: passo 1, imagem 2 %32
    • Remove battery.
    • Remove the label cassette.
  2. Dymo LabelManager 280 Rear Case Replacement: passo 2, imagem 1 %32 Dymo LabelManager 280 Rear Case Replacement: passo 2, imagem 2 %32
    • Remove the 6 screws in the indicated places. These particular screws are 2mm x 8mm Phillips #0 head
  3. Dymo LabelManager 280 Rear Case Replacement: passo 3, imagem 1 %32 Dymo LabelManager 280 Rear Case Replacement: passo 3, imagem 2 %32
    • Use the spudger to take apart the device by insterting it as shown in the picture and twisting it. This should be done all around the device to ensure the two parts split correctly.
    • The keys/buttons highlighted in the second picture fall out easily so be careful. Keep device faced down in order to keep them from falling.
Conclusão
Steven Nguyen
Membro desde: 02/08/16
431 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 6-5, Eyestone Spring 2016 Membro de USF Tampa, Team 6-5, Eyestone Spring 2016
USFT-EYESTONE-S16S6G5
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 29
Duração total: 605
