Ir para o conteúdo principal
Durofix RV332 Motor Replacement
O que você precisa
  1. Durofix RV332 Motor Replacement, Screwdriver Motor: passo 1, imagem 1 %32
    • Remove the six 13 mm case screws with philips #0 screwdriver.
  2. Durofix RV332 Motor Replacement: passo 2, imagem 1 %32 Durofix RV332 Motor Replacement: passo 2, imagem 2 %32
    • Use the plastic separating tool to separate the casing halves of the cordless screwdriver.
  3. Durofix RV332 Motor Replacement: passo 3, imagem 1 %32 Durofix RV332 Motor Replacement: passo 3, imagem 2 %32
    • Once the screwdriver casings have been separated, remove the printed circuit board, battery, LED, and motor assembly from the screwdriver casing.
    • Using the wire cutters, cut the black and red motor wires where they connect to the motor.
  4. Durofix RV332 Motor Replacement: passo 4, imagem 1 %32
    • Strip the ends of the wires clean with the wire cutters. Strip the wire insulation 1/4" from the end of the wire.
  5. Durofix RV332 Motor Replacement: passo 5, imagem 1 %32 Durofix RV332 Motor Replacement: passo 5, imagem 2 %32 Durofix RV332 Motor Replacement: passo 5, imagem 3 %32
    • Ensure the new motor terminals are clean before soldering.
    • Solder the red wire to the positive motor terminal, designated by a plus sign with a red circle around it.
    • Solder the black wire to the other terminal of the motor.
    • Allow the newly soldered assembly to cool before continuing.
  6. Durofix RV332 Motor Replacement: passo 6, imagem 1 %32
    • Once the motor has cooled, replace the motor, printed circuit board, LED, and battery inside the screwdriver casing.
Conclusão
Tyler Vincent
Membro desde: 02/24/14
479 Reputação
Autoria de 4 guias
Equipe
Michigan Tech, Team 5-5, Lauer Spring 2014 Membro de Michigan Tech, Team 5-5, Lauer Spring 2014
MTU-LAUER-S14S5G5
Membros da 3
Autoria de 5 guias
Um comentário
Too late finding this (although self-explanatory). I was wondering when I tried this - WHERE does one find the spare component motor to replace? I searched the internet, but for something so specific, I just couldn't locate the right channels. For future reference, is there a typical store of small motors, etc... to locate these things?
Arkadiusz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 813
