Ir para o conteúdo principal
Durofix RV332 Battery Replacement
O que você precisa
  1. Durofix RV332 Battery Replacement, Battery: passo 1, imagem 1 %32 Durofix RV332 Battery Replacement, Battery: passo 1, imagem 2 %32 Durofix RV332 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Remove the six 13mm case screws with a #0 phillips screwdriver.
    • Separate the screwdriver housing with a plastic opening tool.
    • Remove battery casing half to expose screwdriver internals.
  2. Durofix RV332 Battery Replacement: passo 2, imagem 1 %32 Durofix RV332 Battery Replacement: passo 2, imagem 2 %32
    • Locate battery
    • Remove battery, printed circuit board, LED, and motor assembly from screwdriver casing.
  3. Durofix RV332 Battery Replacement: passo 3, imagem 1 %32
    • Using side cutters, cut the red and black wires connecting the battery to the printed circuit board just after the shrink wrap tubing.
    • Strip the ends of the wires attached to the printed circuit board 1/4 inch above the ends of the cut wires.
    • Solder the new battery to the stripped wires attached to the printed circuit board.
    • Wrap the newly soldered connections with electrical tape.
Conclusão
Brennan Wade
Membro desde: 02/21/14
122 Reputação
Autoria de 1 guia
Equipe
Michigan Tech, Team 5-5, Lauer Spring 2014 Membro de Michigan Tech, Team 5-5, Lauer Spring 2014
MTU-LAUER-S14S5G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 13
Duração total: 2,694
