Ir para o conteúdo principal
Ducky One 3 SF Keycaps and Switches Replacement
O que você precisa
  1. Ducky One 3 SF Keycaps and Switches Replacement, Keycaps and Switches: passo 1, imagem 1 %32 Ducky One 3 SF Keycaps and Switches Replacement, Keycaps and Switches: passo 1, imagem 2 %32
    • Disconnect the cable from your keyboard.
    • Place the keyboard on a flat and stable surface.
  2. Ducky One 3 SF Keycaps and Switches Replacement: passo 2, imagem 1 %32 Ducky One 3 SF Keycaps and Switches Replacement: passo 2, imagem 2 %32 Ducky One 3 SF Keycaps and Switches Replacement: passo 2, imagem 3 %32
    • Use the switch puller to remove the keycap from the keyboard.
    • Remove all of the keycaps you need to replace or clean.
  3. Ducky One 3 SF Keycaps and Switches Replacement: passo 3, imagem 1 %32 Ducky One 3 SF Keycaps and Switches Replacement: passo 3, imagem 2 %32
    • Place the keycaps in a container.
  4. Ducky One 3 SF Keycaps and Switches Replacement: passo 4, imagem 1 %32 Ducky One 3 SF Keycaps and Switches Replacement: passo 4, imagem 2 %32 Ducky One 3 SF Keycaps and Switches Replacement: passo 4, imagem 3 %32
    • Use a key switch puller to secure the switch at the top and bottom.
    • Pull the switch away from the keyboard.
    • Ensure the switch puller is positioned and secured between the switch and the keyboard to prevent any damage to the switch.
  5. Ducky One 3 SF Keycaps and Switches Replacement: passo 5, imagem 1 %32
    • Place all of the switches from the keyboard in a container.
  6. Ducky One 3 SF Keycaps and Switches Replacement: passo 6, imagem 1 %32
    • Use a dust blower to remove loose debris from your keyboard.
    • Use a foam tipped swab and Isopropyl Alcohol to clean any residue, oils, or grime from the keyboard.
    • Make sure the keyboard is completely dry before replacing the switches and keycaps.
  7. Ducky One 3 SF Keycaps and Switches Replacement: passo 7, imagem 1 %32
    • Soak the keycaps in soapy water.
    • Remove all dirt or debris from each keycap.
  8. Ducky One 3 SF Keycaps and Switches Replacement: passo 8, imagem 1 %32
    • Let the keycaps sit for 10-20 minutes to disinfect.
    • Rinse the keycaps with water.
    • Place them on a towel and use a cloth to remove excess water.
    • Leave the keycaps to air dry.
    • Ensure that the keycaps are completely dry before proceeding to the next step.
  9. Ducky One 3 SF Keycaps and Switches Replacement: passo 9, imagem 1 %32 Ducky One 3 SF Keycaps and Switches Replacement: passo 9, imagem 2 %32 Ducky One 3 SF Keycaps and Switches Replacement: passo 9, imagem 3 %32
    • Insert the new switch into the corresponding holes in the keyboard and push the switch into position.
    • Make sure that the switch pins line up correctly with the holes on the keyboard so they don't get bent or damaged.
    • Continue the process until all switches are in place.
  10. Ducky One 3 SF Keycaps and Switches Replacement: passo 10, imagem 1 %32 Ducky One 3 SF Keycaps and Switches Replacement: passo 10, imagem 2 %32 Ducky One 3 SF Keycaps and Switches Replacement: passo 10, imagem 3 %32
    • Replace each keycap in the correct position and press onto the key switch.
    • Use the following website to confirm both the correct positioning and functionality of the keycap.
Conclusão
Hopefully these steps were clear and useful to you!
Uma outra pessoa concluiu este guia.
Tony Lee
Membro desde: 01/10/24
181 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 32
Duração total: 133
