Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Use this guide to remove a defective touchpad on a Dualshock 4 controller.
O que você precisa
Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the following buttons:
Share button
Options button
Split the plastic covers of the controller apart, taking note that they will still be attached by circuit board ribbons.
2 Trigger Springs
1 Grey Reset Button Extension
Use tweezers or your fingers to grab and disconnect the head of the battery cable from the motherboard.
Remove the single 6.0 mm Phillips screw found below the battery retainer with the Phillips #00 Screwdriver.
Gently detach the touchpad ribbon connected to the motherboard using the blunt forceps. The touchpad ribbon is connected to the motherboard by a connector that flips to tighten and loosen. During reassembly, to reattach the ribbon, the plastic tray will need to be gently removed from the motherboard and the flip-lock flipped up.
Successful disassembly of the controller will result in the following three parts, respectively:
Motherboard Assembly
Front Cover
Rear Cover
After the motherboard is set aside, lay the front panel on the ground.
You can now see the touch pad which is outlined on the top and bottom by an orange line.
26 outras pessoas executaram este guia.
5 comentários
when put back the right side and the bottom doesnt click properly. What am I doing wrong?
You ever figure this out?
I disassembled my controller and changed the sticks and case now the controller moves on it's own and gets stuck when moving ... How can I fix this or is there something I may have done wrong when I was reassembling it???
when i took the ribbon cable out, the cover when with it now i cant put the cover back so i can put back the cable
