Ir para o conteúdo principal
DualShock 4 Ribbon Cable Replacement
O que você precisa
  1. DualShock 4 Ribbon Cable Replacement, Check your controller model: passo 1, imagem 1 %32
    • Check the model number on the back of your controller. This guide was written using model CUH-ZCT1U. If you have another model, the guide procedure and replacement parts may differ slightly.
    • If you have the second generation DualShock 4, model CUH-ZCT2U, use these guides.
  2. DualShock 4 Ribbon Cable Replacement, Unfasten the rear case: passo 2, imagem 1 %32 DualShock 4 Ribbon Cable Replacement, Unfasten the rear case: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Microfiber Cleaning Cloths
    $3.99
    Comprar
    • If you need to stabilize your controller during this repair, lay it on a soft surface such as a microfiber cloth.
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws securing the rear case.
  3. DualShock 4 Ribbon Cable Replacement, Remove the L1 button: passo 3, imagem 1 %32 DualShock 4 Ribbon Cable Replacement, Remove the L1 button: passo 3, imagem 2 %32 DualShock 4 Ribbon Cable Replacement, Remove the L1 button: passo 3, imagem 3 %32
    • Use an opening pick to pry each corner of the L1 button from the front case.
    • Cover the button to prevent it from ejecting out of your workspace.
    • Remove the button.
  4. DualShock 4 Ribbon Cable Replacement, Remove the R1 button: passo 4, imagem 1 %32
    • Use your opening pick to pry and remove the R1 button, just as you did for the L1 button.
  5. DualShock 4 Ribbon Cable Replacement, Unclip the rear case: passo 5, imagem 1 %32 DualShock 4 Ribbon Cable Replacement, Unclip the rear case: passo 5, imagem 2 %32 DualShock 4 Ribbon Cable Replacement, Unclip the rear case: passo 5, imagem 3 %32
    • Six plastic clips secure the rear case to the front case. The next four steps demonstrate how to release these clips before you can open the controller.
    • Insert your opening pick at a downward angle between the front case and rear case, halfway between the handle and the action buttons.
    • Slide your pick toward the handle and pry up to release the first clip.
    • Repeat this procedure on the other side of the controller to release the second clip.
  6. DualShock 4 Ribbon Cable Replacement: passo 6, imagem 1 %32 DualShock 4 Ribbon Cable Replacement: passo 6, imagem 2 %32 DualShock 4 Ribbon Cable Replacement: passo 6, imagem 3 %32
    • Two more clips secure the rear case near the extension port and the headphone jack.
    • Insert your opening pick between the front case and rear case at either side of the ports.
    • Twist your pick to unclip this section of the rear case from the front case.
    • If the rear case feels stuck, insert and twist your pick from different angles.
    • Don't open the controller yet, as it's still held together by two very delicate clips near the triggers.
  7. DualShock 4 Ribbon Cable Replacement: passo 7, imagem 1 %32
    • The final two clips are very delicate, and must be disengaged from inside the controller. If you break them, don't worry—it won't affect this repair or your controllers functionality.
    • Locate the clips by looking through the gap above the R2 or L2 buttons.
  8. DualShock 4 Ribbon Cable Replacement: passo 8, imagem 1 %32 DualShock 4 Ribbon Cable Replacement: passo 8, imagem 2 %32 DualShock 4 Ribbon Cable Replacement: passo 8, imagem 3 %32
    • Insert the point of a spudger through the gap above the R2 button and push the retaining clip outward.
    • While pushing the clip outward, slowly pull the rear case away from the front case until you feel them separate.
    • Don't fully open the controller until each of the R2 and L2 clips have been disengaged.
    • Repeat this procedure for the clip near the L2 button.
  9. DualShock 4 Ribbon Cable Replacement, Remove the rear case: passo 9, imagem 1 %32 DualShock 4 Ribbon Cable Replacement, Remove the rear case: passo 9, imagem 2 %32 DualShock 4 Ribbon Cable Replacement, Remove the rear case: passo 9, imagem 3 %32
    • Press the R2 button and slide the rear case over it.
  10. DualShock 4 Ribbon Cable Replacement: passo 10, imagem 1 %32
    • Press the L2 button and slide the rear case over it.
  11. DualShock 4 Ribbon Cable Replacement: passo 11, imagem 1 %32 DualShock 4 Ribbon Cable Replacement: passo 11, imagem 2 %32 DualShock 4 Ribbon Cable Replacement: passo 11, imagem 3 %32
    • Flip the rear case over the top of the controller and lay it down, being careful not to strain the interconnect cable.
  12. DualShock 4 Ribbon Cable Replacement, Disconnect the interconnect cable: passo 12, imagem 1 %32 DualShock 4 Ribbon Cable Replacement, Disconnect the interconnect cable: passo 12, imagem 2 %32 DualShock 4 Ribbon Cable Replacement, Disconnect the interconnect cable: passo 12, imagem 3 %32
    • Use tweezers or your fingers to remove the interconnect cable by pulling its blue pull tab straight out of the socket.
    • During reassembly, reconnect the cable with its blue pull tab facing the outside of the controller.
  13. DualShock 4 Ribbon Cable Replacement, Unfasten the light guide bracket: passo 13, imagem 1 %32
    • Use your Phillips screwdriver to remove the two 6.4 mm screws securing the light guide bracket to the rear case.
  14. DualShock 4 Ribbon Cable Replacement, Remove the light bar bracket: passo 14, imagem 1 %32 DualShock 4 Ribbon Cable Replacement, Remove the light bar bracket: passo 14, imagem 2 %32 DualShock 4 Ribbon Cable Replacement, Remove the light bar bracket: passo 14, imagem 3 %32
    • Remove the black spacer and white bracket from the light guide.
  15. DualShock 4 Ribbon Cable Replacement, Peel the foam pads: passo 15, imagem 1 %32 DualShock 4 Ribbon Cable Replacement, Peel the foam pads: passo 15, imagem 2 %32 DualShock 4 Ribbon Cable Replacement, Peel the foam pads: passo 15, imagem 3 %32
    • Peel both foam pads from the light guide.
  16. DualShock 4 Ribbon Cable Replacement, Remove the light guide: passo 16, imagem 1 %32 DualShock 4 Ribbon Cable Replacement, Remove the light guide: passo 16, imagem 2 %32 DualShock 4 Ribbon Cable Replacement, Remove the light guide: passo 16, imagem 3 %32
    • Grab and lift the light guide from its alignment pegs on the rear case.
    • Remove the light guide.
  17. DualShock 4 Ribbon Cable Replacement, Remove the light diffuser: passo 17, imagem 1 %32 DualShock 4 Ribbon Cable Replacement, Remove the light diffuser: passo 17, imagem 2 %32 DualShock 4 Ribbon Cable Replacement, Remove the light diffuser: passo 17, imagem 3 %32
    • Push the light diffuser through the inside of the rear case and remove it.
  18. DualShock 4 Ribbon Cable Replacement, Ribbon Cable: passo 18, imagem 1 %32 DualShock 4 Ribbon Cable Replacement, Ribbon Cable: passo 18, imagem 2 %32
    • Use your thumb to hold down the clear plastic cover to create space to remove the ribbon cable.
    • With the cover held down, use tweezers to remove the faulty ribbon cable.
Conclusão
5 outras pessoas executaram este guia.
Mohamed Ahmed
Membro desde: 01/27/21
352 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 94
Últimos 30 dias: 436
Duração total: 15,401
