Ir para o conteúdo principal
DualShock 4 CUH-ZCT2 Rear Panel Replacement
O que você precisa
  1. DualShock 4 CUH-ZCT2 Rear Panel Replacement, Remove the rear panel screws: passo 1, imagem 1 %32 DualShock 4 CUH-ZCT2 Rear Panel Replacement, Remove the rear panel screws: passo 1, imagem 2 %32
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
  2. DualShock 4 CUH-ZCT2 Rear Panel Replacement, Separate the rear panel: passo 2, imagem 1 %32 DualShock 4 CUH-ZCT2 Rear Panel Replacement, Separate the rear panel: passo 2, imagem 2 %32
    • Four fragile plastic clips hold the panels together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
    • Gently pry the rear panel off of the front panel until they become partially separated.
  3. DualShock 4 CUH-ZCT2 Rear Panel Replacement, Release the plastic clips: passo 3, imagem 1 %32 DualShock 4 CUH-ZCT2 Rear Panel Replacement, Release the plastic clips: passo 3, imagem 2 %32 DualShock 4 CUH-ZCT2 Rear Panel Replacement, Release the plastic clips: passo 3, imagem 3 %32
    • Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
  4. DualShock 4 CUH-ZCT2 Rear Panel Replacement, Remove the rear panel: passo 4, imagem 1 %32 DualShock 4 CUH-ZCT2 Rear Panel Replacement, Remove the rear panel: passo 4, imagem 2 %32
    • Lift the rear panel directly away from the controller.
    • Do not completely remove the rear panel. It is still attached to the controller by a ribbon cable.
  5. DualShock 4 CUH-ZCT2 Rear Panel Replacement: passo 5, imagem 1 %32 DualShock 4 CUH-ZCT2 Rear Panel Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
    • Since this cable's pull tab is too small to grab with fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • During reassembly, grab the ribbon cable by the blue tab and gently press the cable straight into the connector. Push the blue tab rather than the ribbon cable itself.
Conclusão
4 outras pessoas executaram este guia.
Sam Omiotek
Membro desde: 02/25/19
92.212 Reputação
Autoria de 290 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 30
Últimos 30 dias: 122
Ao todo: 5,061
