Ir para o conteúdo principal
DualShock 4 CUH-ZCT1 Charging Port Replacement
O que você precisa
  1. DualShock 4 CUH-ZCT1 Charging Port Replacement, Charging Port: passo 1, imagem 1 %32
    • Flip the Dualshock 4 controller on its back, and use a Phillips #00 screwdriver to remove the four 6 mm screws.
  2. DualShock 4 CUH-ZCT1 Charging Port Replacement: passo 2, imagem 1 %32
    • Slowly lift the backplate onto the front side of the controller making sure not to fully remove the backplate.
  3. DualShock 4 CUH-ZCT1 Charging Port Replacement: passo 3, imagem 1 %32 DualShock 4 CUH-ZCT1 Charging Port Replacement: passo 3, imagem 2 %32
    • Remove the ribbon cable from the motherboard of the controller and place the top half of the controller on the side for later.
  4. DualShock 4 CUH-ZCT1 Charging Port Replacement: passo 4, imagem 1 %32
    • Remove the light bar's sub-assembly by gently lifting up the piece.
  5. DualShock 4 CUH-ZCT1 Charging Port Replacement: passo 5, imagem 1 %32
    • Lift the clear plastic piece out of the controller by pulling into the controller and removing it.
  6. DualShock 4 CUH-ZCT1 Charging Port Replacement: passo 6, imagem 1 %32
    • Remove the two 6 mm Phillips screws that are on top of the PCB of the charging port.
  7. DualShock 4 CUH-ZCT1 Charging Port Replacement: passo 7, imagem 1 %32 DualShock 4 CUH-ZCT1 Charging Port Replacement: passo 7, imagem 2 %32
    • Gently wiggle the charging port's PCB side to side until it detaches from the controller.
Conclusão
8 outras pessoas executaram este guia.
Andy Lam
Membro desde: 01/31/23
331 Reputação
Autoria de 1 guia
Equipe
1Comentário do guia
One thing I thought I'd leave here is in-case you wanted to upgrade to USB-C at the same time, this is an aftermarket product that can let you do that - https://www.tindie.com/products/mariushe...
Works an absolute treat, and the quality is astoundingly good :D
Aadi Bhamidipati - Responder
Comentar
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 64
Últimos 30 dias: 368
Ao todo: 7,302
