Ir para o conteúdo principal
DualShock 4 CHU-ZCT2U Charging Assembly Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Charging Assembly(LED and USB port chip): passo 1, imagem 1 %32 DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Charging Assembly(LED and USB port chip): passo 1, imagem 2 %32 DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Charging Assembly(LED and USB port chip): passo 1, imagem 3 %32
    • Remove the 4 screws (6.0 mm), which is on the back of the controller, using Phillips #00 screwdriver
    • Place the removed screws to the side.
  2. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: passo 2, imagem 1 %32 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: passo 2, imagem 2 %32 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: passo 2, imagem 3 %32
    • Detach the top frame from the bottom frame by carefully pulling them apart.
  3. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: passo 3, imagem 1 %32 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: passo 3, imagem 2 %32
    • Carefully remove the white ribbon connector that is connected to both frames from the top side ( the side where the battery is).
  4. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: passo 4, imagem 1 %32 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: passo 4, imagem 2 %32 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: passo 4, imagem 3 %32
    • Take the bottom part (the side without the battery).
    • Remove the white plastic cover which is on the top of the Charging assembly.
  5. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: passo 5, imagem 1 %32 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: passo 5, imagem 2 %32 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: passo 5, imagem 3 %32
    • Remove the plastic cover which is in front of the Charging assembly.
    • Remove the transparent plastic cover which is on top of the Charging assembly.
    • Be careful while removing all plastic covers since they are very delicate and can break if removed forcefully.
  6. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: passo 6, imagem 1 %32 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: passo 6, imagem 2 %32 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: passo 6, imagem 3 %32
    • Remove the two screw (4.00 mm) using the #00 Phillips screwdriver, which is holding the Charging assembly and the frame together.
    • Remove the double-sided tape, with the plastic opening tool, that is keeping the chip attached to the frame.
    • Take out the charging assembly chip.
  7. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: passo 7, imagem 1 %32 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: passo 7, imagem 2 %32 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: passo 7, imagem 3 %32
    • Remove the white ribbon cable from the charging assembly chip.
    • Replace the Charging assembly chip with a new one.
Conclusão
If you have followed all the steps correctly, your LED Light should light up once you reassemble and plug your device to a USB cord. To reassemble your device, follow these instructions in reverse order.
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 3,054
