Ir para o conteúdo principal
DualShock 4 CHU-ZCT2U Battery Case Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. DualShock 4 CHU-ZCT2U Battery Case Replacement, Outer Shell: passo 1, imagem 1 %32 DualShock 4 CHU-ZCT2U Battery Case Replacement, Outer Shell: passo 1, imagem 2 %32 DualShock 4 CHU-ZCT2U Battery Case Replacement, Outer Shell: passo 1, imagem 3 %32
    • Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
    • Pry the two halves of the shell apart using a plastic opening tool.
    • Be careful, as there will be a ribbon connecting the inner workings of the controller. It will not separate into two parts just by pulling apart the shell.
  2. DualShock 4 CHU-ZCT2U Battery Case Replacement: passo 2, imagem 1 %32 DualShock 4 CHU-ZCT2U Battery Case Replacement: passo 2, imagem 2 %32 DualShock 4 CHU-ZCT2U Battery Case Replacement: passo 2, imagem 3 %32
    • Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
  3. DualShock 4 CHU-ZCT2U Battery Case Replacement, Battery: passo 3, imagem 1 %32 DualShock 4 CHU-ZCT2U Battery Case Replacement, Battery: passo 3, imagem 2 %32 DualShock 4 CHU-ZCT2U Battery Case Replacement, Battery: passo 3, imagem 3 %32
    • Unplug the black and red wires from the power port located on the motherboard.
    • Remove the old battery from the controller.
  4. DualShock 4 CHU-ZCT2U Battery Case Replacement: passo 4, imagem 1 %32 DualShock 4 CHU-ZCT2U Battery Case Replacement: passo 4, imagem 2 %32
    • Remove the 6.43mm screw connecting the motherboard to the inner workings of the controller, using a Phillips-Head screwdriver.
  5. DualShock 4 CHU-ZCT2U Battery Case Replacement: passo 5, imagem 1 %32 DualShock 4 CHU-ZCT2U Battery Case Replacement: passo 5, imagem 2 %32 DualShock 4 CHU-ZCT2U Battery Case Replacement: passo 5, imagem 3 %32
    • Unhook the battery case from the motherboard, and pull it off.
Conclusão
19 outras pessoas executaram este guia.
Michelle Joseph
Membro desde: 10/09/17
1.762 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S1-G5, Leahy Fall 2017 Membro de USF Tampa, Team S1-G5, Leahy Fall 2017
USFT-LEAHY-F17S1G5
Membros da 3
Autoria de 22 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 12,312
