Introdução
Use this guide to replace the 3.7 lithium-ion battery inside the DualShock 4.
Ferramentas
Peças
Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
Detach the motherboard ribbon connecting the two sides of the controller by pulling it straight out with your fingers.
After the two halves are separated, place the top of the controller off to the side.
96 outras pessoas concluíram este guia.
15 comentários
My Dualshock 4 wont turn on after the battery replacement.
Any idea on why this happened?
have you tried to charge it?
The only replacement battery option listed in the 'relevant parts' section of the guide is for a used battery. Here is a a link to a new replacement battery for those that don't want to do this again in a few months. It is higher capacity than the OEM battery (1300mAh instead of 1000mAh) so it will last longer. Hope this helps!
My samsung galaxy tab 2 7inch screen goes black help
