Introdução
Use this guide to remove the rear cover of a DualShock 3 controller.
O que você precisa
Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
24 outras pessoas executaram este guia.
3 comentários
i have a different dualshock 3 than yours. mine is built in a different way and has a different battery
Sony did that throughout the Dualshock 3’s production as they found out what would cause them to malfunction and fixed the issue. It should be alright as long as you are able to replace the battery when needed.
iran:
نحوهی تعویض طلق دسته پلی سه هم بذارین. لطفان
