Ir para o conteúdo principal
DualShock 3 Battery Replacement
O que você precisa
  1. DualShock 3 Battery Replacement, Step 1: passo 1, imagem 1 %32 DualShock 3 Battery Replacement, Step 1: passo 1, imagem 2 %32 DualShock 3 Battery Replacement, Step 1: passo 1, imagem 3 %32
    • This is the Dualshock 3 controller
    • On the back of the controller, there will be five 7.2mm Phillips screws securing the body of the controller. (The five screws are circled in black.)
    • Remove each of the five screws from the back of the DualShock controller.
  2. DualShock 3 Battery Replacement, Step 2: passo 2, imagem 1 %32
    • Push the center of the rear cover (between the two analog sticks) and carefully lift the lower edge away from the rest of the controller.
  3. DualShock 3 Battery Replacement, Step 3: passo 3, imagem 1 %32
    • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
    • Pull the rear cover away from the rest of the controller, but be careful so that you won't pop off the #2 triggers.
    • Here is a DualShock trigger guide on the IFIXIT website in case you need to reattach the #2 triggers.
  4. DualShock 3 Battery Replacement, Step 4: passo 4, imagem 1 %32
    • Move the battery off the motherboard so you have enough clearance to access the battery connector.
  5. DualShock 3 Battery Replacement, Step 5: passo 5, imagem 1 %32 DualShock 3 Battery Replacement, Step 5: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Carefully pull the battery connector away from the socket that is attached to the motherboard. ( Battery connector is circled in black.)
    • It may be safer to use a tool like tweezers or pliers to pull the battery connector out of the socket.
    • Now you can dispose of the old battery safely. For example taking old used batteries to a household hazardous waste facility.
Conclusão
3 outras pessoas executaram este guia.
Marcus Aiken
Membro desde: 11/08/16
214 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 26
Últimos 30 dias: 168
Ao todo: 4,158
