Ir para o conteúdo principal
DualShock 3 Battery Replacement
O que você precisa
  1. DualShock 3 Battery Replacement, Rear Cover: passo 1, imagem 1 %32
    • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
    Pergunte ao FixBot
  2. DualShock 3 Battery Replacement: passo 2, imagem 1 %32
    • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
    Pergunte ao FixBot
  3. DualShock 3 Battery Replacement: passo 3, imagem 1 %32 DualShock 3 Battery Replacement: passo 3, imagem 2 %32
    • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
    • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
    • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
    Pergunte ao FixBot
  4. DualShock 3 Battery Replacement, Battery: passo 4, imagem 1 %32
    • Lift the battery off the motherboard for enough clearance to access the battery connector.
    Pergunte ao FixBot
  5. DualShock 3 Battery Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Carefully pull the battery connector away from its socket on the motherboard.
    • It may be helpful to use a pair of tweezers or pliers to grab the battery connector when you disconnect it for the first time. Only pull on the connector. Do not try to remove by pulling on the red and black wires.
    Pergunte ao FixBot
Conclusão
168 outras pessoas executaram este guia.
20Comentários do guia
I got the shell separated but unfortunately snapped the lil plastic clip on the rear of the controller's bottom half. a lil super glue and treezers fixed tht up nicely...Thanks for the help
KUDOS to you!!!
Rob (rjmat42)
Robert - Responder Compartilhar
I have different battery on my second controller, battery itself have pins to connect it with board, no more white plastic holder :/
Raf - Responder Compartilhar
Try Amazon Cody
linzikerner - Responder Compartilhar
whats is amazon cody?
Albert Einstein - Responder Compartilhar
Anyone have any idea where I can find the plastic retainers for the battery? I bought the new one, but my old battery has the clips attached. I don't want this thing just jiggling around in there, it'll drive me nuts.
Thanks.
geoquin4 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 53
Últimos 7 dias: 318
Últimos 30 dias: 1,411
Ao todo: 231,791
