Ir para o conteúdo principal
Dual Hard Drive #80
Pré-requisito somente
Este é um guia somente para pré-requisitos! Este guia faz parte de outro procedimento e não deve ser usado sozinho.
O que você precisa
  1. Dual Hard Drive #80, Dual Hard Drive: passo 1, imagem 1 %32 Dual Hard Drive #80, Dual Hard Drive: passo 1, imagem 2 %32
    • Remove the plastic spacer from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
  2. Dual Hard Drive #80: passo 2, imagem 1 %32 Dual Hard Drive #80: passo 2, imagem 2 %32 Dual Hard Drive #80: passo 2, imagem 3 %32
    • Make sure that the hard drive connectors are facing down before placing it into the enclosure.
    • Gently place the hard drive into the enclosure's hard drive slot.
    • While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
  3. Dual Hard Drive #80: passo 3, imagem 1 %32 Dual Hard Drive #80: passo 3, imagem 2 %32
    • Once the hard drive is snug, reinsert the plastic spacer while holding the hard drive against the bottom of the enclosure.
  4. Dual Hard Drive #80: passo 4, imagem 1 %32 Dual Hard Drive #80: passo 4, imagem 2 %32
    • Use two Phillips #1 screws to secure the drive to its enclosure.
  5. Dual Hard Drive #80: passo 5, imagem 1 %32
    • Attach the optical drive bracket to the new enclosure with two Phillips #0 screws.
    • Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
  6. Dual Hard Drive #80: passo 6, imagem 1 %32 Dual Hard Drive #80: passo 6, imagem 2 %32 Dual Hard Drive #80: passo 6, imagem 3 %32
    • Don't ditch that drive! You can still use your optical drive externally with the help of our SATA Optical Drive USB Cable.
    • Align the cable's SATA connector with the drive's port and plug in securely.
    • Plug the USB connector into your laptop and your optical drive is ready for use.
Conclusão
Brittany McCrigler
Membro desde: 03/05/12
90.618 Reputação
Autoria de 142 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.927 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 454
