Ir para o conteúdo principal
Droid Ultra XT1080 Power Button Replacement
O que você precisa
  1. Droid Ultra XT1080 Power Button Replacement, Power Button: passo 1, imagem 1 %32 Droid Ultra XT1080 Power Button Replacement, Power Button: passo 1, imagem 2 %32 Droid Ultra XT1080 Power Button Replacement, Power Button: passo 1, imagem 3 %32
    • Gently remove the SIM card tray from the device using a spudger.
  2. Droid Ultra XT1080 Power Button Replacement: passo 2, imagem 1 %32
    • After SIM card removal press the spudger between the plastic case and the frame until you hear a snap.
    • Work your way around the device until all the clips are released.
    • Be gentle while doing this so you don't crack or break the plastic.
  3. Droid Ultra XT1080 Power Button Replacement: passo 3, imagem 1 %32
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Power Button Replacement: passo 4, imagem 1 %32 Droid Ultra XT1080 Power Button Replacement: passo 4, imagem 2 %32
    • Once the screws are removed, use a nylon spudger and lift up on the two plastic pieces that were secured by the screws.
  5. Droid Ultra XT1080 Power Button Replacement: passo 5, imagem 1 %32
    • Remove the four T5 Torx screws securing the motherboard.
  6. Droid Ultra XT1080 Power Button Replacement: passo 6, imagem 1 %32
    • Gently pry the motherboard out of the frame using the plastic opening tool.
  7. Droid Ultra XT1080 Power Button Replacement: passo 7, imagem 1 %32 Droid Ultra XT1080 Power Button Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    $3.99
    • Once motherboard is removed you have gained access to the power button.
    • Gently, using a pair of angled tweezers pull on the power button to remove it.
Conclusão
knoyes
Membro desde: 10/30/18
785 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S3-G8, Peak Fall 2018 Membro de UMass Dartmouth, Team S3-G8, Peak Fall 2018
UMASSD-PEAK-F18S3G8
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 423
