Ir para o conteúdo principal
Droid Ultra XT1080 Charging Port Replacement
O que você precisa
  1. Droid Ultra XT1080 Charging Port  Replacement, Charging Port: passo 1, imagem 1 %32
    • Remove SIM card tray from the device with a plastic opening tool.
  2. Droid Ultra XT1080 Charging Port  Replacement: passo 2, imagem 1 %32
    • Once SIM card tray is removed press the spudger between the plastic case and the frame of the device until you hear a snap.
    • Work your away around the device until all the plastic clips are undone.
    • Be gentle with the plastic to make sure it doesn't break.
  3. Droid Ultra XT1080 Charging Port  Replacement: passo 3, imagem 1 %32
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Charging Port  Replacement: passo 4, imagem 1 %32 Droid Ultra XT1080 Charging Port  Replacement: passo 4, imagem 2 %32
    • Once the screws are removed, use a plastic spudger and lift up the two plastic pieces that were secured by the screws.
  5. Droid Ultra XT1080 Charging Port  Replacement: passo 5, imagem 1 %32
    • Remove the four T5 Torx screws securing the motherboard.
  6. Droid Ultra XT1080 Charging Port  Replacement: passo 6, imagem 1 %32
    • Gently pry the motherboard out of the frame of the device.
  7. Droid Ultra XT1080 Charging Port  Replacement: passo 7, imagem 1 %32 Droid Ultra XT1080 Charging Port  Replacement: passo 7, imagem 2 %32
    • Once the motherboard is free flip it over on its back so all the components are showing.
  8. Droid Ultra XT1080 Charging Port  Replacement: passo 8, imagem 1 %32
    • To fully replace the charging port you need to desolder the port and solder a new one in.
Conclusão
Uma outra pessoa concluiu este guia.
knoyes
Membro desde: 10/30/18
785 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S3-G8, Peak Fall 2018 Membro de UMass Dartmouth, Team S3-G8, Peak Fall 2018
UMASSD-PEAK-F18S3G8
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 823
