Ir para o conteúdo principal
Droid Ultra XT1080 Battery Replacement
O que você precisa
  1. Droid Ultra XT1080 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove the SIM card tray from the side of the device using a plastic opening tool.
  2. Droid Ultra XT1080 Battery Replacement: passo 2, imagem 1 %32
    • After properly removing the SIM card tray take your spudger and press it in between the plastic case and the frame of the device until you hear a snap.
    • Work your way from the top and the other side to confirm all the clips are disconnected.
    • Be gentle when performing this so you don't crack or break the plastic.
  3. Droid Ultra XT1080 Battery Replacement: passo 3, imagem 1 %32
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Battery Replacement: passo 4, imagem 1 %32 Droid Ultra XT1080 Battery Replacement: passo 4, imagem 2 %32
    • After the top and bottom screws are removed remove the top and bottom plastic pieces that were secured to the device.
  5. Droid Ultra XT1080 Battery Replacement: passo 5, imagem 1 %32
    • Begin to gently pry up the battery from the frame with a plastic opening tool to release it from its adhesive securing.
  6. Droid Ultra XT1080 Battery Replacement: passo 6, imagem 1 %32
    • Remove the four T5 Torx screws securing the motherboard.
  7. Droid Ultra XT1080 Battery Replacement: passo 7, imagem 1 %32 Droid Ultra XT1080 Battery Replacement: passo 7, imagem 2 %32
    • Gently pry the motherboard out of the frame using the nylon spudger.
    • Make sure not to damage the LCD cable in the process.
  8. Droid Ultra XT1080 Battery Replacement: passo 8, imagem 1 %32
    • Disconnect the LCD cable with a spudger from the motherboard by gently lifting up the two connectors.
Conclusão
3 outras pessoas executaram este guia.
knoyes
Membro desde: 10/30/18
785 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S3-G8, Peak Fall 2018 Membro de UMass Dartmouth, Team S3-G8, Peak Fall 2018
UMASSD-PEAK-F18S3G8
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 2,898
