Ir para o conteúdo principal
Drill Master Heat Gun Power Cord Replacement
O que você precisa
  1. Drill Master Heat Gun Power Cord Replacement, Power Cord: passo 1, imagem 1 %32
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
  2. Drill Master Heat Gun Power Cord Replacement: passo 2, imagem 1 %32
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
  3. Drill Master Heat Gun Power Cord Replacement: passo 3, imagem 1 %32 Drill Master Heat Gun Power Cord Replacement: passo 3, imagem 2 %32 Drill Master Heat Gun Power Cord Replacement: passo 3, imagem 3 %32
    • Remove the barrel casing on either end by twisting and pulling each side off.
  4. Drill Master Heat Gun Power Cord Replacement: passo 4, imagem 1 %32
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
  5. Drill Master Heat Gun Power Cord Replacement: passo 5, imagem 1 %32
    • Loosen four screws on the wire connector using the flathead 2.5 screwdriver.
    • Screws do not come out of connector.
  6. Drill Master Heat Gun Power Cord Replacement: passo 6, imagem 1 %32
    • Disconnect the power cord wiring from the wire connector.
  7. Drill Master Heat Gun Power Cord Replacement: passo 7, imagem 1 %32
    • Remove the two 12mm screws from the base of power cord using the PH#0 screwdriver.
  8. Drill Master Heat Gun Power Cord Replacement: passo 8, imagem 1 %32
    • Remove the power cord from the heat gun.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 695
