Ir para o conteúdo principal
Drift HD 720 Microphone Replacement
O que você precisa
  1. Drift HD 720 Microphone Replacement, Battery: passo 1, imagem 1 %32 Drift HD 720 Microphone Replacement, Battery: passo 1, imagem 2 %32
    • Unscrew the back plate counterclockwise until it comes off.
  2. Drift HD 720 Microphone Replacement: passo 2, imagem 1 %32
    • Push the black battery tab next to the battery to get the battery out.
    • Remove the battery.
  3. Drift HD 720 Microphone Replacement, Microphone: passo 3, imagem 1 %32
    • Remove six 8mm long Philips head screws with the J0 Philips head from the outer case.
  4. Drift HD 720 Microphone Replacement: passo 4, imagem 1 %32
    • Remove the back case from the camera body.
  5. Drift HD 720 Microphone Replacement: passo 5, imagem 1 %32
    • Remove the battery housing from the camera body.
  6. Drift HD 720 Microphone Replacement: passo 6, imagem 1 %32
    • Remove the microphone first from the rubber housing it is located in, after which you will disconnect the wires connecting the microphone to the motherboard from where they are attached on the motherboard. You will then solder the new speakers wires in the same locations on the motherboard as the wires you just removed.
Conclusão
Hector Rodriquez
Membro desde: 09/23/15
422 Reputação
Autoria de 4 guias
Equipe
Baylor, Team 10-16, Williams Fall 2015 Membro de Baylor, Team 10-16, Williams Fall 2015
BU-WILLIAMS-F15S10G16
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 361
