Ir para o conteúdo principal
Dresser Drawer Guide Tracks Replacement
O que você precisa
  1. Dresser Drawer Guide Tracks Replacement, Broken Guide Tracks for a Dresser Drawer: passo 1, imagem 1 %32 Dresser Drawer Guide Tracks Replacement, Broken Guide Tracks for a Dresser Drawer: passo 1, imagem 2 %32
    • As you can see, the guide tracks that set the drawer in place are no longer attached to the dresser in the correct position.
  2. Dresser Drawer Guide Tracks Replacement: passo 2, imagem 1 %32
    • You will need super glue and a staple gun because the dresser and the tracks are wooden. You can also use screws and a screwdriver if you would like.
  3. Dresser Drawer Guide Tracks Replacement: passo 3, imagem 1 %32
    • Apply the glue to both sides on the wooden tracks. You will only need a small amount.
  4. Dresser Drawer Guide Tracks Replacement: passo 4, imagem 1 %32 Dresser Drawer Guide Tracks Replacement: passo 4, imagem 2 %32
    • Now you will want to place the tracks in the desired location inside the dresser. You will want to apply pressure from the top of the track to secure the clue to the wood. Let this dry for about 5-10 minutes.
  5. Dresser Drawer Guide Tracks Replacement: passo 5, imagem 1 %32 Dresser Drawer Guide Tracks Replacement: passo 5, imagem 2 %32
    • Once your clue has dried, you can now use the staple gun to ensure that the track is secure.
  6. Dresser Drawer Guide Tracks Replacement: passo 6, imagem 1 %32 Dresser Drawer Guide Tracks Replacement: passo 6, imagem 2 %32
    • Finally, once the tracks have been set and are secure, you can align your drawer to the tracks and slide the drawer back into the dresser.
Linha de Chegada
jackson feld
Membro desde: 10/29/19
133 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 30
Últimos 30 dias: 96
Ao todo: 3,956
