Ir para o conteúdo principal
Dress Shirt Button Replacement
O que você precisa
  1. Dress Shirt Button Replacement, Button: passo 1, imagem 1 %32 Dress Shirt Button Replacement, Button: passo 1, imagem 2 %32
    • Measure out two feet of thread and cut it.
  2. Dress Shirt Button Replacement: passo 2, imagem 1 %32 Dress Shirt Button Replacement: passo 2, imagem 2 %32 Dress Shirt Button Replacement: passo 2, imagem 3 %32
    • The needle is sharp. Be careful when working.
    • Put the thread through the eye of the needle.
    • Pull the thread through so that both ends are even.
    • Tie both strings into a knot, closing the loop
  3. Dress Shirt Button Replacement: passo 3, imagem 1 %32 Dress Shirt Button Replacement: passo 3, imagem 2 %32
    • Begin sewing by putting the needle through the back of the fabric, out to the front, and through a hole in the button.
    • Make sure the button is facing the correct direction.
  4. Dress Shirt Button Replacement: passo 4, imagem 1 %32 Dress Shirt Button Replacement: passo 4, imagem 2 %32 Dress Shirt Button Replacement: passo 4, imagem 3 %32
    • Put the needle through the hole diagonal and feed through to the back of the shirt
    • Repeat this process for the other diagonal.
    • Repeat the process of sewing through the diagonals multiple times.
  5. Dress Shirt Button Replacement: passo 5, imagem 1 %32
    • When there is about 4 inches of thread yet, push the thread so that it is on the back side of the fabric.
    • Then push the needle back through making sure to not go through the button again.
  6. Dress Shirt Button Replacement: passo 6, imagem 1 %32 Dress Shirt Button Replacement: passo 6, imagem 2 %32 Dress Shirt Button Replacement: passo 6, imagem 3 %32
    • Wrap the thread around the button 4-6 times.
  7. Dress Shirt Button Replacement: passo 7, imagem 1 %32 Dress Shirt Button Replacement: passo 7, imagem 2 %32 Dress Shirt Button Replacement: passo 7, imagem 3 %32
    • Push the thread back through to the back side of the fabric.
    • Tie the knot off and cut.
Conclusão
Your shirt is now ready to be worn again.
Jonathan Wong
Membro desde: 04/09/15
225 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 28-4, Green Spring 2015 Membro de Cal Poly, Team 28-4, Green Spring 2015
CPSU-GREEN-S15S28G4
6 Membros
Autoria de 17 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 20
Últimos 30 dias: 75
Ao todo: 4,682
