Ir para o conteúdo principal
Dremel MultiPro 395 Casing Replacement
O que você precisa
  1. Dremel MultiPro 395 Casing Replacement, Casing: passo 1, imagem 1 %32 Dremel MultiPro 395 Casing Replacement, Casing: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove the blue caps located on either side of the MultiPro, using a 3 mm flathead screwdriver.
  2. Dremel MultiPro 395 Casing Replacement: passo 2, imagem 1 %32 Dremel MultiPro 395 Casing Replacement: passo 2, imagem 2 %32
    • Carefully remove the carbon brushes attached at the end of the springs by gently pulling on the springs using your hands.
  3. Dremel MultiPro 395 Casing Replacement: passo 3, imagem 1 %32 Dremel MultiPro 395 Casing Replacement: passo 3, imagem 2 %32
    • Pull one side of the hanger up and then pull away from the Multipro until the other side can be pulled out.
  4. Dremel MultiPro 395 Casing Replacement: passo 4, imagem 1 %32 Dremel MultiPro 395 Casing Replacement: passo 4, imagem 2 %32 Dremel MultiPro 395 Casing Replacement: passo 4, imagem 3 %32
    • Remove the 4 screws located on the bottom of the Multipro with a T15 screwdriver.
  5. Dremel MultiPro 395 Casing Replacement: passo 5, imagem 1 %32 Dremel MultiPro 395 Casing Replacement: passo 5, imagem 2 %32 Dremel MultiPro 395 Casing Replacement: passo 5, imagem 3 %32
    • Hold down the collet lock, remove the chuck cap from the top of the Multipro by screwing counterclockwise.
  6. Dremel MultiPro 395 Casing Replacement: passo 6, imagem 1 %32 Dremel MultiPro 395 Casing Replacement: passo 6, imagem 2 %32 Dremel MultiPro 395 Casing Replacement: passo 6, imagem 3 %32
    • Remove the black housing cap from the Multipro located directly below the chuck cap.
  7. Dremel MultiPro 395 Casing Replacement: passo 7, imagem 1 %32 Dremel MultiPro 395 Casing Replacement: passo 7, imagem 2 %32 Dremel MultiPro 395 Casing Replacement: passo 7, imagem 3 %32
    • Pull the bottom side of the casing up to remove it.
  8. Dremel MultiPro 395 Casing Replacement: passo 8, imagem 1 %32 Dremel MultiPro 395 Casing Replacement: passo 8, imagem 2 %32 Dremel MultiPro 395 Casing Replacement: passo 8, imagem 3 %32
    • Gently lift the motor shaft out of the Multipro.
  9. Dremel MultiPro 395 Casing Replacement: passo 9, imagem 1 %32 Dremel MultiPro 395 Casing Replacement: passo 9, imagem 2 %32 Dremel MultiPro 395 Casing Replacement: passo 9, imagem 3 %32
    • Pull the lock pin and its casing out of the other side of the Multipro case.
Conclusão
3 outras pessoas executaram este guia.
2Comentários do guia
A link to parts is always nice,
bari - Responder
Yay! Got my old 395 warrior back to working condition! Many thanks!
Eduardo Capocchi - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Ao todo: 2,534
