Ir para o conteúdo principal
Dremel 8200 Disassembly
O que você precisa
  1. Dremel 8200 Disassembly, Dremel 8200 Disassembly: passo 1, imagem 1 %32 Dremel 8200 Disassembly, Dremel 8200 Disassembly: passo 1, imagem 2 %32
    • Take off the screw cap at the top
  2. Dremel 8200 Disassembly: passo 2, imagem 1 %32 Dremel 8200 Disassembly: passo 2, imagem 2 %32
    • Take out the battery
    • Remove oblong belt clip
  3. Dremel 8200 Disassembly: passo 4, imagem 1 %32
    • Unscrew screws
    • Take back u clip out carefully
    • Be very careful to not injure yourself
  4. Dremel 8200 Disassembly: passo 6, imagem 1 %32 Dremel 8200 Disassembly: passo 6, imagem 2 %32
    • The casing should just open right up and be easily accessible
  5. Dremel 8200 Disassembly: passo 7, imagem 1 %32
    • You can remove the buttons except for the sliding one that adjusts the speed
  6. Dremel 8200 Disassembly: passo 8, imagem 1 %32 Dremel 8200 Disassembly: passo 8, imagem 2 %32
    • You can take the motor out first and it will be a little hard to do so
    • Work your way down and take out each successive circuit board
    • The last thing to be out should be the sliding speed adjustment and the button for that should fall right out
Conclusão
3 outras pessoas executaram este guia.
2 comentários
It will be handy to have either a can of compressed air or an air directional nozzle on your compressor. Be careful of the circuits and small parts that can blow away. You'll be amazed how even with a maintenance schedule, how much dirt will be on the motor fins
m. D. w. - Responder
How do you replace just the bearing in this assembly?
Andre Da Silva - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 8
Últimos 30 dias: 43
Duração total: 3,592
