Ir para o conteúdo principal
Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement
O que você precisa
  1. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Battery: passo 1, imagem 1 %32 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Battery: passo 1, imagem 2 %32 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Battery: passo 1, imagem 3 %32
    • Pull back on the release tabs to disconnect the battery pack from the housing.
    • When installing a new battery, you may need to charge it before using it.
  2. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Motor-Shaft Assembly: passo 2, imagem 1 %32 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Motor-Shaft Assembly: passo 2, imagem 2 %32 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Motor-Shaft Assembly: passo 2, imagem 3 %32
    • Remove the two screws from the back of the device with the TR10 Torx Security screwdriver.
    • Make sure you have removed the battery before proceeding as accidentally powering-on the device while disassembling is dangerous due to the high-speed components inside.
  3. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: passo 3, imagem 1 %32 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: passo 3, imagem 2 %32 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: passo 3, imagem 3 %32
    • Lift off the unscrewed plastic cover at an angle, away from the tip of the device.
    • Gently lift the cover. It won't take much force to remove it.
  4. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: passo 4, imagem 1 %32 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: passo 4, imagem 2 %32 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: passo 4, imagem 3 %32
    • Lift the tip of the motor-shaft assembly gently, then pull the assembly out.
    • The blue battery contact and the spring for the shaft lock button may pop out when you remove the motor-shaft assembly. Make sure to keep track of these pieces, as they are very small.
Conclusão
3 outras pessoas executaram este guia.
Michael Smith
Membro desde: 02/10/16
175 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 3-4, Sullivan Spring 2016 Membro de USF Tampa, Team 3-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G4
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 26
Duração total: 3,111
