Ir para o conteúdo principal
Dremel 7300 MiniMite Cordless Collet Replacement
O que você precisa
  1. Dremel 7300 MiniMite Cordless Collet Replacement, Collet: passo 1, imagem 1 %32 Dremel 7300 MiniMite Cordless Collet Replacement, Collet: passo 1, imagem 2 %32 Dremel 7300 MiniMite Cordless Collet Replacement, Collet: passo 1, imagem 3 %32
    • The device comes with a small black wrench to tighten the collet nut, during reassembly or changing the bits.
    • Press the blue button and hold it down.
    • Unscrew the collet nut, with your fingers (as if you were going to change the bit).
    • Continue until the collet nut comes completely off of the Dremel.
  2. Dremel 7300 MiniMite Cordless Collet Replacement: passo 2, imagem 1 %32 Dremel 7300 MiniMite Cordless Collet Replacement: passo 2, imagem 2 %32 Dremel 7300 MiniMite Cordless Collet Replacement: passo 2, imagem 3 %32
    • Once the collet nut is off, you can remove the collet. It is the silver part that grips the bit when the collet nut tightens on it.
    • The collet itself may be in the shaft, or come off with the nut.
Conclusão
7 outras pessoas executaram este guia.
Kat
Membro desde: 02/10/16
840 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 3-4, Sullivan Spring 2016 Membro de USF Tampa, Team 3-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G4
4 Membros
Autoria de 4 guias
2Comentários do guia
Too anyone having trouble unscrewing the collet, you may want to clamp vice grips on if its stuck tight. Worked for me.
Will - Responder
I easily removed the bit by holding the blue button and using the black wrench to loosen it and then I remove the silver piece that holds the bit then when I tried to use another one of the attachments it seems like it’s too large to fit in there I haven’t been able to use any of the other attachments like polishing and the finer little grinders
Kate Denkers - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 16
Ao todo: 32,690
