Ir para o conteúdo principal
Dreamer Autoshade Motor Set Screw Adjustment
O que você precisa
  1. Dreamer Autoshade Motor Set Screw Adjustment, Remove motor hub fasteners: passo 1, imagem 1 %32 Dreamer Autoshade Motor Set Screw Adjustment, Remove motor hub fasteners: passo 1, imagem 2 %32
    • Remove the four Phillips head screws that fasten the motor hub to the tube adapter.
  2. Dreamer Autoshade Motor Set Screw Adjustment, Remove driver bearing cap: passo 2, imagem 1 %32 Dreamer Autoshade Motor Set Screw Adjustment, Remove driver bearing cap: passo 2, imagem 2 %32
    • Using a flathead screwdriver, pry the bearing cap from the tube.
  3. Dreamer Autoshade Motor Set Screw Adjustment, Tighten Motor Set Screw: passo 3, imagem 1 %32
    • Move the hub to the edge of the shaft so it is flush, and tighten the set screw using a T5 screwdriver bit.
    • The hub should fit snugly on the shaft, unable to rotate freely.
    • Optional- Add a drop of thread locking liquid to permanently hold the set screw in place after tightening.
Conclusão
David
Membro desde: 11/11/20
734 Reputação
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 211
