Ir para o conteúdo principal
Dreamer Autoshade Idle Tube Length Adjustment
  1. Dreamer Autoshade Idle Tube Length Adjustment, Mark tube: passo 1, imagem 1 %32 Dreamer Autoshade Idle Tube Length Adjustment, Mark tube: passo 1, imagem 2 %32
    • Before adjusting the size of your tube, make sure you try adjusting the left side mounting nub. This guide is meant for users whose idle tubes are too long to fit after attempting to fit with the left-hand nub adjusted.
    • Measure the amount needed to remove in order to fit the shade in the wall mounts.
    • Measure and mark the distance needed to remove. Repeat this process to draw a circle around the entire tube.
  2. Dreamer Autoshade Idle Tube Length Adjustment, Shorten tube: passo 2, imagem 1 %32
    • Use a sander, hacksaw, or appropriate metal cutoff saw to shorten the tube to the desired length. Be sure to use the required safety procedures for your chosen method.
  3. Dreamer Autoshade Idle Tube Length Adjustment, Replace left bearing cap: passo 3, imagem 1 %32
    • Replace the bearing cap and nub on the left side of the shade tube.
Conclusão
David
Membro desde: 11/11/20
734 Reputação
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Ao todo: 205
