Ir para o conteúdo principal
Draining a Toilet Tank
  1. Draining a Toilet Tank, Tank Lid: passo 1, imagem 1 %32 Draining a Toilet Tank, Tank Lid: passo 1, imagem 2 %32 Draining a Toilet Tank, Tank Lid: passo 1, imagem 3 %32
    • Lift the tank lid up and away from the toilet tank.
  2. Draining a Toilet Tank, Shutting off the Water Supply to a Toilet: passo 2, imagem 1 %32 Draining a Toilet Tank, Shutting off the Water Supply to a Toilet: passo 2, imagem 2 %32
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Draining a Toilet Tank, Draining a Toilet Tank: passo 3, imagem 1 %32 Draining a Toilet Tank, Draining a Toilet Tank: passo 3, imagem 2 %32
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
Conclusão
Most toilets retain a small amount of water in the tank after draining. To remove any excess water from the bottom of your toilet tank, use our guide for Sponge Drying a Toilet Tank.
Uma outra pessoa concluiu este guia.
Ron Davis
Membro desde: 02/17/15
32.081 Reputação
Autoria de 13 guias
2Comentários do guia
I have a cracking in my toilet tank going almost the length of the tank and below water line resulting in a leak. In your experience is a sealant a good option or in reality would the tank need to be replaced in time ?
Thanks
K EVANS - Responder
It would make more sense to replace the tank, than seal any crack which would only reappear after time anyway.
John Turner -
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 20
Últimos 30 dias: 115
Ao todo: 34,110
