Ir para o conteúdo principal
Dragon Touch MID 7138 Motherboard Replacement
O que você precisa
  1. Dragon Touch MID 7138 Motherboard Replacement, Back Cover: passo 1, imagem 1 %32
    • Wedge a plastic spudger between the back panel and the screen to begin lifting the back cover.
    • Wedge around all edges until the back cover pops off entirely.
  2. Dragon Touch MID 7138 Motherboard Replacement: passo 2, imagem 1 %32
    • Gently pry the back cover from the screen using your hands.
  3. Dragon Touch MID 7138 Motherboard Replacement, Motherboard: passo 3, imagem 1 %32 Dragon Touch MID 7138 Motherboard Replacement, Motherboard: passo 3, imagem 2 %32 Dragon Touch MID 7138 Motherboard Replacement, Motherboard: passo 3, imagem 3 %32
    • Remove tape covering wire joints
    • Remove (3) 2.5mm screws using a PH001 screw driver.
    • The screws locations are highlighted in the image to the left.
  4. Dragon Touch MID 7138 Motherboard Replacement: passo 4, imagem 1 %32
    • Remove black tape and using your fingers, pull the orange ribbon labeled BSR028-V3-KDX out of its port.
  5. Dragon Touch MID 7138 Motherboard Replacement: passo 5, imagem 1 %32
    • Similar to previous step, pull the large U2 ribbon gentle out of its port.
  6. Dragon Touch MID 7138 Motherboard Replacement: passo 6, imagem 1 %32
    • Remove the last orange ribbon labeled 24 by pulling the motherboard away from the ribbon
  7. Dragon Touch MID 7138 Motherboard Replacement: passo 7, imagem 1 %32 Dragon Touch MID 7138 Motherboard Replacement: passo 7, imagem 2 %32
    • Desolder the wires attached to the mother board with a soldering iron.
    • Then pull the wires from the joints.
Conclusão
Trevor Farkas
Membro desde: 01/26/17
101 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 2-4, Baechle Spring 2017 Membro de IUPUI, Team 2-4, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G4
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 592
