Introdução
If your Dr. Martens Mary Janes strap isn't staying because the elastic is worn out or broken, this guide is for you! In this guide, you will be replacing a new elastic shoe strap on your favorite pair of Mary Janes. Before beginning, be sure the new elastic is the same dimensions as the existing elastic on the shoe. Step 10 requires basic sewing knowledge on Sewing a Straight Stitch, reminder to be cautious when using the sewing needle.
O que você precisa
To reassemble your shoe elastic, follow these instructions in reverse order.
