Ir para o conteúdo principal
Dopo Double Power 7 Motherboard Replacement
O que você precisa
    1. Dopo Double Power 7 Motherboard Replacement, Rear Panel: passo 1, imagem 1 %32
      • The rear panel is secured to the front case and can simply be pried apart without damage.
      Pergunte ao FixBot
      Comentar
    2. Dopo Double Power 7 Motherboard Replacement: passo 2, imagem 1 %32
      • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
      Pergunte ao FixBot
      Comentar
    3. Dopo Double Power 7 Motherboard Replacement: passo 3, imagem 1 %32
      • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
      Pergunte ao FixBot
      Comentar
    4. Dopo Double Power 7 Motherboard Replacement: passo 4, imagem 1 %32
      • The rear panel should come completely off.
      Pergunte ao FixBot
      Comentar
    1. Dopo Double Power 7 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
      • Remove any static tape covering the motherboard.
      Pergunte ao FixBot
      Comentar
    2. Dopo Double Power 7 Motherboard Replacement: passo 6, imagem 1 %32 Dopo Double Power 7 Motherboard Replacement: passo 6, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Using the flat end of a spudger or tweezers, remove the three cables connected to the motherboard.
      • The cables can be disconnected by lifting up on the black section of the socket, as shown by the arrow.
      • Once the lever is lifted, pull out the cable by gently tugging on it.
      Pergunte ao FixBot
      Comentar
    3. Dopo Double Power 7 Motherboard Replacement: passo 7, imagem 1 %32
      • Using a Phillips Head Screwdriver size 0, remove the four screws attaching the motherboard.
      Pergunte ao FixBot
      Comentar
    4. Dopo Double Power 7 Motherboard Replacement: passo 8, imagem 1 %32 Dopo Double Power 7 Motherboard Replacement: passo 8, imagem 2 %32
      • Using wire cutters, cut the red, black, and grays wires.
      • The motherboard can now be removed
      • Leave enough wire to be re-soldered back if possible.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
mike pelosi
Membro desde: 10/30/15
682 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 1-2, Miles Fall 2015 Membro de UMass Dartmouth, Team 1-2, Miles Fall 2015
UMASSD-MILES-F15S1G2
4 Membros
Autoria de 72 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 21
Últimos 30 dias: 56
Ao todo: 820
