Ir para o conteúdo principal
Doorknob Privacy Pin Replacement
O que você precisa
  1. Doorknob Privacy Pin Replacement, Doorknob Privacy Pin: passo 1, imagem 1 %32 Doorknob Privacy Pin Replacement, Doorknob Privacy Pin: passo 1, imagem 2 %32 Doorknob Privacy Pin Replacement, Doorknob Privacy Pin: passo 1, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the two screws holding the interior and exterior doorknob halves together.
  2. Doorknob Privacy Pin Replacement: passo 2, imagem 1 %32 Doorknob Privacy Pin Replacement: passo 2, imagem 2 %32
    • Carefully pull the doorknob halves apart.
    • The spindle and the latch mechanism should now be accessible.
  3. Doorknob Privacy Pin Replacement: passo 3, imagem 1 %32 Doorknob Privacy Pin Replacement: passo 3, imagem 2 %32 Doorknob Privacy Pin Replacement: passo 3, imagem 3 %32
    • Use the Phillips #1 screwdriver to remove the privacy pin.
    • It is a small, threaded pin that screws into a hole on the latch mechanism itself or on the interior doorknob assembly.
  4. Doorknob Privacy Pin Replacement: passo 4, imagem 1 %32
    • Remove the old/ damaged privacy pin.
  5. Doorknob Privacy Pin Replacement: passo 5, imagem 1 %32 Doorknob Privacy Pin Replacement: passo 5, imagem 2 %32 Doorknob Privacy Pin Replacement: passo 5, imagem 3 %32
    • Screw the new privacy pin into the corresponding hole.
    • Ensure it's securely tightened but don't overtighten, as this could strip the threads.
  6. Doorknob Privacy Pin Replacement: passo 6, imagem 1 %32 Doorknob Privacy Pin Replacement: passo 6, imagem 2 %32 Doorknob Privacy Pin Replacement: passo 6, imagem 3 %32
    • Align the spindle with the latch mechanism, then bring the two doorknob halves back together.
    • Make sure all parts are properly seated.
  7. Doorknob Privacy Pin Replacement: passo 7, imagem 1 %32 Doorknob Privacy Pin Replacement: passo 7, imagem 2 %32 Doorknob Privacy Pin Replacement: passo 7, imagem 3 %32
    • Securely fasten the two screws with the Phillips #1 screwdriver.
    • Snap or twist the decorative covers back into place (If applicable).
    • Test the privacy pin several times to ensure it engages and disengages smoothly.
Conclusão
Elias Moseri
Membro desde: 06/15/25
145 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 35
Ao todo: 258
