Ir para o conteúdo principal
Door Stop Replacement
O que você precisa
  1. Door Stop Replacement, Door Stop: passo 1, imagem 1 %32 Door Stop Replacement, Door Stop: passo 1, imagem 2 %32 Door Stop Replacement, Door Stop: passo 1, imagem 3 %32
    • Twist the anchor fitting of the old door stop in counter clockwise direction.
    • Remove the anchor fitting from the mount.
    • Anchor fitting: is a part of the door stop circled in red.
  2. Door Stop Replacement: passo 2, imagem 1 %32 Door Stop Replacement: passo 2, imagem 2 %32 Door Stop Replacement: passo 2, imagem 3 %32
    • Use a drill (or a screwdriver) to remove the two screws from the mount base.
    • After you remove the mount base, use the hammer to reposition these two screws.
  3. Door Stop Replacement: passo 3, imagem 1 %32 Door Stop Replacement: passo 3, imagem 2 %32
    • Use a screwdriver to remove the mount base out of the new anchor fitting by spinning the screwdriver counter-clockwise.
  4. Door Stop Replacement: passo 4, imagem 1 %32 Door Stop Replacement: passo 4, imagem 2 %32 Door Stop Replacement: passo 4, imagem 3 %32
    • Using a screwdriver or a drill, attach the new mount base to the wall with the two screws.
  5. Door Stop Replacement: passo 5, imagem 1 %32 Door Stop Replacement: passo 5, imagem 2 %32 Door Stop Replacement: passo 5, imagem 3 %32
    • Attach the anchor fitting into the mount base by rotating it clockwise.
  6. Door Stop Replacement: passo 6, imagem 1 %32 Door Stop Replacement: passo 6, imagem 2 %32
    • Remove the old door fitting by rotating it counter-clockwise.
  7. Door Stop Replacement: passo 7, imagem 1 %32 Door Stop Replacement: passo 7, imagem 2 %32 Door Stop Replacement: passo 7, imagem 3 %32
    • Use the drill to remove the two screws out of the threaded insert.
    • Clean the screws holes (if necessary) before putting a new screw in.
  8. Door Stop Replacement: passo 8, imagem 1 %32 Door Stop Replacement: passo 8, imagem 2 %32 Door Stop Replacement: passo 8, imagem 3 %32
    • Insert a screwdriver into the bottom hole of the threaded insert and rotate it counter-clockwise to remove the threaded insert.
  9. Door Stop Replacement: passo 9, imagem 1 %32 Door Stop Replacement: passo 9, imagem 2 %32
    • Place the threaded insert onto the door.
    • Using a screwdriver or a drill, attach the threaded insert to the door with two screws.
  10. Door Stop Replacement: passo 10, imagem 1 %32 Door Stop Replacement: passo 10, imagem 2 %32 Door Stop Replacement: passo 10, imagem 3 %32
    • Assemble the rest of the door stop in the following order:
    • Spring.
    • Rectangular compartment.
    • Door stop button.
    • Outer shell.
    • Place the door stopper onto the threaded insert and and attach it by rotating it clockwise.
Conclusão
Khoa Bui
Membro desde: 09/20/20
198 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 14
Últimos 30 dias: 46
Ao todo: 4,270
