Ir para o conteúdo principal
Door Hinge Replacement
O que você precisa
  1. Door Hinge Replacement, Hinge: passo 1, imagem 1 %32 Door Hinge Replacement, Hinge: passo 1, imagem 2 %32
    • Take measurements of the door hinge using a tape measure and use the measurements to find a replacement door hinge.
  2. Door Hinge Replacement: passo 2, imagem 1 %32 Door Hinge Replacement: passo 2, imagem 2 %32
    • Use two sturdy pieces of wood or cardboard that can keep the door in place and put them underneath the door.
    • Make sure that the door isn’t slanted or tilted to make it easier to replace the new door hinge.
  3. Door Hinge Replacement: passo 3, imagem 1 %32 Door Hinge Replacement: passo 3, imagem 2 %32
    • Remove the three screws from the hinge that are connected to the door by using a Phillips 1 screwdriver.
    • Remove the three screws from the hinge that are connected to the door frame using a Phillips #1 screwdriver.
  4. Door Hinge Replacement: passo 4, imagem 1 %32 Door Hinge Replacement: passo 4, imagem 2 %32
    • Repeat Step 3 with the bottom hinge on the door.
  5. Door Hinge Replacement: passo 5, imagem 1 %32 Door Hinge Replacement: passo 5, imagem 2 %32
    • Rub sandpaper on the areas where the new hinges will be.
    • This makes sure that splinters or any wood debris from both the frame and the door will be removed.
  6. Door Hinge Replacement: passo 6, imagem 1 %32 Door Hinge Replacement: passo 6, imagem 2 %32
    • When replacing your new door hinge, make sure that the hinge that is facing towards you can be fully closed
  7. Door Hinge Replacement: passo 7, imagem 1 %32 Door Hinge Replacement: passo 7, imagem 2 %32 Door Hinge Replacement: passo 7, imagem 3 %32
    • Align the new door hinge with the screw holes in the frame and screw in the new door hinge in the frame.
    • Repeat this with the bottom area of the door.
  8. Door Hinge Replacement: passo 8, imagem 1 %32 Door Hinge Replacement: passo 8, imagem 2 %32 Door Hinge Replacement: passo 8, imagem 3 %32
    • Align the new door hinge with the screw holes in the door and screw in the new door hinge.
  9. Door Hinge Replacement: passo 9, imagem 1 %32 Door Hinge Replacement: passo 9, imagem 2 %32
    • Spray a small amount of WD-40 at the back top and bottom hinge and wipe it down with an old rag.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Zeniff Aviles
Membro desde: 01/19/21
234 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 799
