Introdução
This guide will instruct users how to replace a door frame's damaged strike plate. This will allow for the door's lock to catch onto the strike plate.
A strike plate might need to be replaced because it is too damaged to properly work. If the door's lock is not catching onto the strike plate and firmly staying in place, the strike plate may need to be replaced.
O que você precisa
With a screwdriver, remove the two screws holding the strike plate in place.
Quase terminado!
Linha de Chegada
