Ir para o conteúdo principal
Door Frame Strike Plate Replacement
O que você precisa
  1. Door Frame Strike Plate Replacement, Strike Plate: passo 1, imagem 1 %32
    • With a screwdriver, remove the two screws holding the strike plate in place.
    • The screwdriver used during this guide will vary due to the size of the pre-existing screws.
  2. Door Frame Strike Plate Replacement: passo 2, imagem 1 %32
    • Remove the damaged strike plate from the door frame.
    • Depending on the type of strike plate, the strike plate may not remain in place after removing both of the screws.
  3. Door Frame Strike Plate Replacement: passo 3, imagem 1 %32
    • Replace the damaged strike plate with a new strike plate.
    • The holes of the new strike plate should align with the holes of the damaged strike plate. If they do not, new holes on the door frame would need to be drilled.
  4. Door Frame Strike Plate Replacement: passo 4, imagem 1 %32
    • Apply the new strike plate to the frame of the door, and ensure that the strike plate's holes are aligned with the drilled-in holes on the door frame.
  5. Door Frame Strike Plate Replacement: passo 5, imagem 1 %32
    • Screw in the top screw first, ensuring that the strike plate will remain in place. Then, screw in the bottom screw.
  6. Door Frame Strike Plate Replacement: passo 6, imagem 1 %32
    • Ensure that the strike plate is not loose by trying to wiggle the strike plate with your hand.
    • If the strike plate budges, continue screwing in the screws until it does not budge.
Linha de Chegada
Brandon Cline
Membro desde: 01/30/18
133 Reputação
Autoria de 1 guia
Um comentário
How do I fill the old hole as my new plate does not line up ?
DeniseB - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 24
Últimos 30 dias: 90
Duração total: 4,947
