Introdução
Installing a new charging port may be necessary if you are having trouble charging your battery. Installation should only be done as a last resort, after trying other possible solutions as listed in the Nokia 8290 Troubleshooting Guide. Installation requires no prior knowledge of mobile phone charging ports.
Peças
Não são necessárias peças.
  1. Locate the small button on the top of the phone. Depress the button. With your other hand, pull the front cover away from the phone.
    • Locate the small button on the top of the phone.
    • Depress the button.
    • With your other hand, pull the front cover away from the phone.
  2. Remove all six 5.3 mm long T6 screws. Remove the circuit board/faceplate sub-assembly from the back of the phone. Take care to place screws in a safe location.
    • Remove all six 5.3 mm long T6 screws.
    • Remove the circuit board/faceplate sub-assembly from the back of the phone.
    • Take care to place screws in a safe location.
  3. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Use tweezers to remove the indicated part. The part is black with six metal connectors. Its approximate dimensions are 12.3 mm x 8.4 mm x 8.2 mm. The part is black with six metal connectors. Its approximate dimensions are 12.3 mm x 8.4 mm x 8.2 mm.
    • Use tweezers to remove the indicated part.
    • The part is black with six metal connectors. Its approximate dimensions are 12.3 mm x 8.4 mm x 8.2 mm.
  5. There is another part located directly underneath the part removed in the previous step. Use tweezers to remove this part as well. The part is black with four rectangular spaces in the bottom. Its approximate dimensions are 10.4 mm x 6.6 mm x 4.5 mm. The part is black with four rectangular spaces in the bottom. Its approximate dimensions are 10.4 mm x 6.6 mm x 4.5 mm.
    • There is another part located directly underneath the part removed in the previous step. Use tweezers to remove this part as well.
    • The part is black with four rectangular spaces in the bottom. Its approximate dimensions are 10.4 mm x 6.6 mm x 4.5 mm.
  6. After removing the two parts, locate the charging port. Use tweezers to remove the charging port. Use tweezers to remove the charging port.
    • After removing the two parts, locate the charging port.
    • Use tweezers to remove the charging port.
Conclusão
Parker Niebauer
1 reputação
6 Guides authored
Equipe
Clemson, Team 15-3, Benson Fall 2012 Membro de Clemson, Team 15-3, Benson Fall 2012
CLEM-BENSON-F12S15G3
3 Membros
21 Guides authored
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Todo: 331
