Ir para o conteúdo principal
Dismountable Hand Blender
O que você precisa
  1. Dismountable Hand Blender, Dismountable Hand Blender: passo 1, imagem 1 %32
    • Finding and fixing the problem is a cinch!
    • Disassembling the mixer is very destructive!
    • This appliance is a clear example of planned obsolescence since a worn (carbon) brush makes it fit for the trash.
    • If the fault is in the electronic module, clever cutting can make an acceptable repair possible as shown in this ElectroMax video.
  2. Dismountable Hand Blender: passo 2, imagem 1 %32 Dismountable Hand Blender: passo 2, imagem 2 %32 Dismountable Hand Blender: passo 2, imagem 3 %32
    • The speed control knob is easy to disassemble by inserting a knife blade under the graduated circle and prying it up.
    • There are three obstacles to the removal of the motor and electronics module from this mixer:
    • The entire motor block enclosure is firmly secured with adhesive.
    • This motor bearing fastener acts as a circular mount.
    • This plunger system fastener is a second circular mount.
    • I do not see a way around any of these three issues without a certain amount of "destruction".
  3. Dismountable Hand Blender: passo 3, imagem 1 %32
    • One of the two leads has broken off. Possibly made fragile by improper assembly?
    • Correctly resoldering the lead lets the motor operate normally again.
Conclusão
We do need to cut the shell off the mixer, which makes salvaging this part difficult.
4 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
fr en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Louis Possoz
Membro desde: 01/10/15
435 Reputação
Autoria de 3 guias
Equipe
Repair Café Louvain-la-Neuve Membro de Repair Café Louvain-la-Neuve
Local Repair Groups
Membros da 2
Autoria de 6 guias
Um comentário
pourquoi acheter du matériel pro si on ne peut pas le réparer
laurencedelanoue - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 27
Últimos 30 dias: 194
Duração total: 14,722
