Pular para o conteúdo principal
Peças
Nenhum componente especificado.
  1. Remove the two 8mm Phillips#0 screws on the back cover. The motherboard is attaching the two covers together, so don't separate them entirely just yet.
    • Remove the two 8mm Phillips#0 screws on the back cover.
    • The motherboard is attaching the two covers together, so don't separate them entirely just yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  3. Remove the four 6mm Phillips#0 screws  connecting the motherboard and front cover. DO NOT detach the wire connecting the motherboard to the front cover.
    • Remove the four 6mm Phillips#0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  4. Grasp the white wire connector between the tabs and the socket. Wiggle the connector back and forth to remove the front cover from the motherboard.
    • Grasp the white wire connector between the tabs and the socket.
    • Wiggle the connector back and forth to remove the front cover from the motherboard.
Conclusão
Timothy Forrest
Membro desde: 18-04-2013
19 reputação
2 Guias de autoria
Equipe
Cal Poly, Team 12-34, Amido Spring 2013 Membro de Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Membros
8 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Todo: 955
