Introdução
A step-by-step guide to disconnecting the wiring attached to the screen of the Garmin Nuvi 680.
Peças
Nenhum componente especificado.
Flip open the antenna on the back of the device.
Remove the two screws on the antenna cover using a T5 Torx screwdriver.
These screws are 4.42 mm long.
Use a spudger to disconnect the yellow antenna wire from the ZIF connector on the back of the motherboard.
Remove the antenna.
Lift the latches on the ribbon cable connectors. All the ribbon cables may have latches. The right most latch may have a latch that flips in the opposite direction from the others.
Gently pull the ribbon cables out of their connectors. They should slide out easily.
Uma outra pessoa concluiu este guia.
