O que você precisa
Find the gray tab, directly above the power switch, where the blue body of the vacuum meets the gray handle extension
Lift the tab and pull the gray extension bar away from the blue body
Remove the vacuum foot from the main body by gripping each piece firmly and strongly pulling them apart
Using a number 2 Phillips head screwdriver, remove the 6 screws from the base plate of the vacuum foot
Grip the top and bottom plate of the vacuum foot firmly
Pull the plates apart until they are completely separated.
Use the medium size brush to remove the dirt from plates of the vacuum foots
Press the indented side of the center gray latch
Using your other hand carefully separate the nozzle form the motor component
Firmly pinch the gray center ridge of the filter and pull away from the blue nozzle
Locate the warning sticker on the bottom of the motor component
Fold back half the sticker so that it remains attached to only one side of the component
Use the scraper to lift one corner of the warning sticker
Remove the foam vent filter. Brush with toothbrush or another small, soft bristle brush to dislodge dirt particles
Using a number 2 phillips head screwdriver remove all 7 screws from motor component
With the two halves loosened, pry the halves apart enough to remove the handle extension release tab from the end of the motor component
Firmly grip both sides of the central component with your hands aligned vertically
Pry the two halves apart while being sure the bottom half remains flat.
Untangle and unwrap any cords and wires from around the motor
With the component laying on a flat surface gently lift the motor up and away from the blue plastic
Using the small soft bristle brush, gently brush around the motor to dislodge any loose dirt or debris
Um comentário
Thank you!!
I was wondering if there was any way to remove the wheels to remove the long hairs that are stuck inbetween.
