Ir para o conteúdo principal
Disassembling the Nokia 6300
O que você precisa
  1. Disassembling the Nokia 6300, Rear Cover: passo 1, imagem 1 %32
    • Take off the back cover by pushing it down and sliding it backwards.
  2. Disassembling the Nokia 6300: passo 2, imagem 1 %32 Disassembling the Nokia 6300: passo 2, imagem 2 %32
    • Take out the battery, SIM card, and MicroSD card.
    • Unscrew the two T6 Torx screws.
  3. Disassembling the Nokia 6300: passo 3, imagem 1 %32
    • Try to seperate the front cover from the rest of the phone. The front cover is held by four plastic clips.
    • The first time you do this you may have to use some force but do it in a controlled way. If you break the plastic clips you'll need a new front cover.
  4. Disassembling the Nokia 6300: passo 4, imagem 1 %32
    • You can take off the keypad now, this is sitting loose on top of the sensors.
    • Unscrew the four remaining T6 Torx screws.
    • The screws holding the motherboard in place are different from the two previous screws which held the rear cover in place.
  5. Disassembling the Nokia 6300: passo 5, imagem 1 %32
    • The motherboard with it's screen are now loose, you can pop it right out.
    • If you've been using this phone for a while, there's probably some dust inside the back shell.
    • There's a lot of contacts exposed, so make sure not to damage those.
  6. Disassembling the Nokia 6300: passo 6, imagem 1 %32 Disassembling the Nokia 6300: passo 6, imagem 2 %32 Disassembling the Nokia 6300: passo 6, imagem 3 %32
    • There's your phone!
Conclusão
20 outras pessoas executaram este guia.
LucasJV
Membro desde: 05/18/10
735 Reputação
Autoria de 3 guias
Equipe
Verheij.co Membro de Verheij.co
Business
1 Membro
Autoria de 5 guias
Um comentário
in this where is bluetooth module plzz give me ans @ bhatia.abhi98@gmail.com
abhishek - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 17
Últimos 30 dias: 72
Duração total: 23,816
