Ir para o conteúdo principal
Disassembling the Garmin eTrex Vista-H Outer Case
O que você precisa
  1. Disassembling the Garmin eTrex Vista-H Outer Case, Removing Battery: passo 1, imagem 1 %32
    • Flip the device to the backside, and locate the metal tab at the center of the back cover.
  2. Disassembling the Garmin eTrex Vista-H Outer Case: passo 2, imagem 1 %32
    • Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
  3. Disassembling the Garmin eTrex Vista-H Outer Case: passo 3, imagem 1 %32 Disassembling the Garmin eTrex Vista-H Outer Case: passo 3, imagem 2 %32
    • Lift the battery plate off to either insert or remove 2 AA batteries.
  4. Disassembling the Garmin eTrex Vista-H Outer Case, Disassembling the Garmin eTrex Vista-H Outer Case: passo 4, imagem 1 %32 Disassembling the Garmin eTrex Vista-H Outer Case, Disassembling the Garmin eTrex Vista-H Outer Case: passo 4, imagem 2 %32
    • With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
  5. Disassembling the Garmin eTrex Vista-H Outer Case: passo 5, imagem 1 %32 Disassembling the Garmin eTrex Vista-H Outer Case: passo 5, imagem 2 %32 Disassembling the Garmin eTrex Vista-H Outer Case: passo 5, imagem 3 %32
    • With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
  6. Disassembling the Garmin eTrex Vista-H Outer Case: passo 6, imagem 1 %32
    • Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
    • Do not remove the back panels quickly. If too much force is applied, there is a wire connection that will break.
    • CAUTION! Be careful not to force the tabs inward. This will result in broken tabs.
  7. Disassembling the Garmin eTrex Vista-H Outer Case: passo 7, imagem 1 %32 Disassembling the Garmin eTrex Vista-H Outer Case: passo 7, imagem 2 %32
    • With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
Conclusão
7 outras pessoas executaram este guia.
Ryan Green
Membro desde: 10/17/10
93 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 21-30, Regan Fall 2010 Membro de Cal Poly, Team 21-30, Regan Fall 2010
CPSU-REGAN-F10S21G30
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 4,982
