Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Use a Phillips #00 screwdriver to remove the two screws at the bottom of the camera.
Locate a screw and a rubber covering on the left side of the camera. Slide the rubber covering to expose a second screw.
Remove both screws with the Phillips #00 screwdriver.
Open the battery compartment on the right side of the camera by pushing slightly in the direction of the arrow.
Remove the two screws by the memory card slot using the Phillips #00 screwdriver.
Pull the grey tab towards the back of the camera. Lift the black cover to expose the battery slots.
Remove the two visible screws with the Phillips #00 screwdriver.
Remove the screen battery located to the left of the screen.
Locate the black tabs on either side of the white ribbon.
Use the metal tweezers to gently move these tabs to the outside edges of the ribbon.
Gently pull the white ribbon out from its connection.
Locate the black tabs on either side of the orange ribbon.
Gently pull the orange ribbon out of its connection.
