Ir para o conteúdo principal
Disassembling of Wahl Lithium Ion Trimmer
O que você precisa
  1. Disassembling of Wahl Lithium Ion Trimmer, Disassembling of Wahl Lithium Ion Trimmer: passo 1, imagem 1 %32 Disassembling of Wahl Lithium Ion Trimmer, Disassembling of Wahl Lithium Ion Trimmer: passo 1, imagem 2 %32
    • Begin by removing the rubber grip along the handle.
  2. Disassembling of Wahl Lithium Ion Trimmer: passo 2, imagem 1 %32
    • Remove the screws from the top to take the metal piece and plastic part off.
  3. Disassembling of Wahl Lithium Ion Trimmer: passo 3, imagem 1 %32 Disassembling of Wahl Lithium Ion Trimmer: passo 3, imagem 2 %32
    • Pry open the plastic cover into two separate pieces. The plastic is very durable so don't worry about breaking it upon prying it open.
Conclusão
12 outras pessoas executaram este guia.
nathan
Membro desde: 10/22/13
1.410 Reputação
Autoria de 6 guias
3 comentários
Well this does not show how to properly remove the metal piece that surrounds the power button , which needs to be removed to access 2 screws ( that I can see it) that need to be removed to completely separate the plastic encasement of the intrrnals has
Andrew Beeson - Responder
very helpful for the first two steps. I need like six more between the 2nd step and the last step. but otherwise, very helpful.  Thank you so much
tundraorchid - Responder
Thanks…worked well.
Magpie - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 33
Últimos 30 dias: 135
Duração total: 43,995
