Ir para o conteúdo principal
Disassembling and cleaning of the filter holder on a Quickmill 0385
O que você precisa
  1. Disassembling and cleaning of the filter holder on a Quickmill 0385, Disassembling and cleaning of the filter holder on a Quickmill 0385: passo 1, imagem 1 %32
    • Remove the black tray for an easier disassembly
  2. Disassembling and cleaning of the filter holder on a Quickmill 0385: passo 2, imagem 1 %32 Disassembling and cleaning of the filter holder on a Quickmill 0385: passo 2, imagem 2 %32
    • Move the steam nozzle to the side to have it out of the way.
  3. Disassembling and cleaning of the filter holder on a Quickmill 0385: passo 3, imagem 1 %32
    • Remove the flat head screw in the center of the filter hodler.
  4. Disassembling and cleaning of the filter holder on a Quickmill 0385: passo 4, imagem 1 %32
    • Remove the screen.
  5. Disassembling and cleaning of the filter holder on a Quickmill 0385: passo 5, imagem 1 %32 Disassembling and cleaning of the filter holder on a Quickmill 0385: passo 5, imagem 2 %32
    • Remove the gasket.
  6. Disassembling and cleaning of the filter holder on a Quickmill 0385: passo 6, imagem 1 %32 Disassembling and cleaning of the filter holder on a Quickmill 0385: passo 6, imagem 2 %32
    • Now we have all the parts removed: the screen, the gasket, the hollow screw, the spring and the valve.
    • Remove the pin first.
  7. Disassembling and cleaning of the filter holder on a Quickmill 0385: passo 7, imagem 1 %32
    • Remove the spring.
  8. Disassembling and cleaning of the filter holder on a Quickmill 0385: passo 8, imagem 1 %32
    • Remove the metal plate.
  9. Disassembling and cleaning of the filter holder on a Quickmill 0385: passo 9, imagem 1 %32
    • You are left with the screen and and the hollow screw.
  10. Disassembling and cleaning of the filter holder on a Quickmill 0385: passo 10, imagem 1 %32
    • All parts can be cleaned individually now.
    • It is advisable to also clean the socket of the filter on the machine.
    • Reassemble the parts in reverse order after cleaning.
    • Enjoy your coffee!
Conclusão
Now clean the individual pieces and reassemble in reverse.
3 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
de en
100%
Regis Funke está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Regis Funke
Membro desde: 04/04/16
162 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 48
Últimos 30 dias: 166
Duração total: 11,317
