Ir para o conteúdo principal
Disassembling Acer Aspire 7551G
O que você precisa
  1. Disassembling Acer Aspire 7551G, Disassembling Acer Aspire 7551G: passo 1, imagem 1 %32 Disassembling Acer Aspire 7551G, Disassembling Acer Aspire 7551G: passo 1, imagem 2 %32
    • Remove the battery by sliding the locking latch to the right and pull the battery out.
  2. Disassembling Acer Aspire 7551G: passo 2, imagem 1 %32
    • Use Phillips #000 Screwdriver to remove the case holding screws, remove the 4 screws that hold the back panel.
    • Apply gentle pressure when undoing the screws to preserve the condition of screw heads for future repairs or servicing.
    • It is important to manage all the extracted screws in a manner that will allow you to quickly place them where they belong during the reassembly process. You can take pictures of each step to memorize the screw placement, or purchase a magnetic pad and section the screws on it.
  3. Disassembling Acer Aspire 7551G, removing hard drive: passo 3, imagem 1 %32 Disassembling Acer Aspire 7551G, removing hard drive: passo 3, imagem 2 %32 Disassembling Acer Aspire 7551G, removing hard drive: passo 3, imagem 3 %32
    • To remove the hard drive, undo the screw that holds it in place and carefully pull the HDD to the right.
  4. Disassembling Acer Aspire 7551G: passo 4, imagem 1 %32 Disassembling Acer Aspire 7551G: passo 4, imagem 2 %32
    • To remove the RAM modules just click the metal levers to the right.
    • Remove two black screws from the WiFi card.
    • While removing the antenna wires, make sure to memorize or take a picture of their color and position.
  5. Disassembling Acer Aspire 7551G, removing dvd bay.: passo 5, imagem 1 %32 Disassembling Acer Aspire 7551G, removing dvd bay.: passo 5, imagem 2 %32 Disassembling Acer Aspire 7551G, removing dvd bay.: passo 5, imagem 3 %32
    • Using the Phillips #000 Screwdriver remove the screw that hold the DVD bay in place.
    • Use a spudger to pry the DVD bay away from the case.
  6. Disassembling Acer Aspire 7551G, removing case screws: passo 6, imagem 1 %32 Disassembling Acer Aspire 7551G, removing case screws: passo 6, imagem 2 %32 Disassembling Acer Aspire 7551G, removing case screws: passo 6, imagem 3 %32
    • Use Phillips #000 Screwdriver to remove the case holding screws.
    • Remember to only apply gentle pressure when undoing the screws to preserve the condition of screw heads for future repairs or servicing.
  7. Disassembling Acer Aspire 7551G, remove screws part 2: passo 7, imagem 1 %32 Disassembling Acer Aspire 7551G, remove screws part 2: passo 7, imagem 2 %32 Disassembling Acer Aspire 7551G, remove screws part 2: passo 7, imagem 3 %32
  8. Disassembling Acer Aspire 7551G, removing the screws part 3: passo 8, imagem 1 %32 Disassembling Acer Aspire 7551G, removing the screws part 3: passo 8, imagem 2 %32 Disassembling Acer Aspire 7551G, removing the screws part 3: passo 8, imagem 3 %32
  9. Disassembling Acer Aspire 7551G, remove the keyboard: passo 9, imagem 1 %32 Disassembling Acer Aspire 7551G, remove the keyboard: passo 9, imagem 2 %32 Disassembling Acer Aspire 7551G, remove the keyboard: passo 9, imagem 3 %32
    • To remove the keyboard, pop the three latches away from the keyboard with a spudger.
    • Gently pull the keyboard from the laptop, but be careful not to damage a flex cable that connect it to the motherboard.
  10. Disassembling Acer Aspire 7551G, remove keyboard flex cable: passo 10, imagem 1 %32 Disassembling Acer Aspire 7551G, remove keyboard flex cable: passo 10, imagem 2 %32
    • Move the flex cable away from the keyboard.
    • Place a Flathead screwdriver under the head of the cable and pry it upwards.
  11. Disassembling Acer Aspire 7551G, remove screws and cables of mid frame: passo 11, imagem 1 %32 Disassembling Acer Aspire 7551G, remove screws and cables of mid frame: passo 11, imagem 2 %32 Disassembling Acer Aspire 7551G, remove screws and cables of mid frame: passo 11, imagem 3 %32
    • Use the IC Extractor/Connector Puller to remove the cables.
    • These connectors are extremely fragile, only use minimal force and extreme care.
    • Use the Phillips #000 Screwdriver to remove the frame screws.
  12. Disassembling Acer Aspire 7551G, removing the screen: passo 12, imagem 1 %32 Disassembling Acer Aspire 7551G, removing the screen: passo 12, imagem 2 %32 Disassembling Acer Aspire 7551G, removing the screen: passo 12, imagem 3 %32
    • Remove all black plastic stickers to reveal the hidden screws.
    • Use Phillips #000 Screwdriver to remove the hidden screws.
    • Carefully slide your prybar under the edge and gently pry around the perimeter.
    • Remove the cable from the webcam module
    • Remove the screws that hold the screen to the inner frame.
  13. Disassembling Acer Aspire 7551G, removing the screen part 2: passo 13, imagem 1 %32
    • Gently unplug the LCD cable.
  14. Disassembling Acer Aspire 7551G, opening the case: passo 14, imagem 1 %32 Disassembling Acer Aspire 7551G, opening the case: passo 14, imagem 2 %32 Disassembling Acer Aspire 7551G, opening the case: passo 14, imagem 3 %32
    • Use the iSesamo Opening Tool to pry under the outer edge of the laptop body.
    • After hearing the first click, move the tool around the perimeter until all of the clips are undone.
    • While some force will be required in this step, make sure not to over-apply pressure since extra force might break the plastic clips.
    • After the clips are undone, remove the back cover.
  15. Disassembling Acer Aspire 7551G, removing mainboard: passo 15, imagem 1 %32 Disassembling Acer Aspire 7551G, removing mainboard: passo 15, imagem 2 %32 Disassembling Acer Aspire 7551G, removing mainboard: passo 15, imagem 3 %32
    • Carefully remove the ribbon cable connecting the two halves of the motherboard.
    • Use Phillips #000 Screwdriver to remove the motherboard screws.
    • Use a plastic prybar to remove the LCD connector. Be careful not to break the cable or its plastic holder.
    • Unplug the DC jack cable before removing the motherboard.
  16. Disassembling Acer Aspire 7551G, remove mainboard part 2: passo 16, imagem 1 %32 Disassembling Acer Aspire 7551G, remove mainboard part 2: passo 16, imagem 2 %32 Disassembling Acer Aspire 7551G, remove mainboard part 2: passo 16, imagem 3 %32
    • Remove the disconnected DC jack from its holder.
    • Carefully lift the motherboard out of the case.
    • Use Phillips #000 Screwdriver to remove the screw that is holding the power PCB.
  17. Disassembling Acer Aspire 7551G, removing the DC jack.: passo 17, imagem 1 %32
    • If the replacement of the DC jack is necessary, use the IC Extractor/Connector Puller to safely unplug the connection.
  18. Disassembling Acer Aspire 7551G, remove cooling pads and fan: passo 18, imagem 1 %32
    • Use the IC Extractor/Connector Puller to safely unplug the fan power connector.
  19. Disassembling Acer Aspire 7551G, removing cooling pads and fan part 2: passo 19, imagem 1 %32 Disassembling Acer Aspire 7551G, removing cooling pads and fan part 2: passo 19, imagem 2 %32 Disassembling Acer Aspire 7551G, removing cooling pads and fan part 2: passo 19, imagem 3 %32
    • Use the Phillips #000 Screwdriver to remove the cooling pad screws.
    • Make sure that the screw pressure across the metal plate remain rather constant. Undo the screws by a couple of rotations each, removing them AT the same time.
    • Lift the cooling pads and the fan assembly.
    • Remove the old thermal compound, degrease the surface with rubbing alcohol.
    • Use a can of compressed air to clean the fan assembly.
Conclusão
5 outras pessoas executaram este guia.
Kevin D
Membro desde: 05/02/14
7.294 Reputação
Autoria de 21 guias
2 comentários
Wonderful techniques to follow. Very good explation and practical work.
Sck - Responder
Thanks, glad i could help.
Kevin D - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 52
Duração total: 13,566
