Ir para o conteúdo principal
Disassembling ZTE Racer II Phone
O que você precisa
  1. Disassembling ZTE Racer II Phone, Phone: passo 1, imagem 1 %32
    • Carefully prise the back cover off the phone.
  2. Disassembling ZTE Racer II Phone: passo 2, imagem 1 %32
    • Remove Battery, SIM Card, and MicroSD
    • Remove the four screws located around the edge of the case. They should be very small phillips heads.
  3. Disassembling ZTE Racer II Phone: passo 3, imagem 1 %32
    • Using a flathead screwdriver, carefully prise the black plastic away. It's held in with a series of clips, and should come away easily.
  4. Disassembling ZTE Racer II Phone: passo 4, imagem 1 %32
    • Carefully remove the ribbon cable that connects the capacitive screen to the main board. You need to carefully lift the small tab, then pull the cable out.
  5. Disassembling ZTE Racer II Phone: passo 5, imagem 1 %32 Disassembling ZTE Racer II Phone: passo 5, imagem 2 %32
    • Now using the flathead screwdriver, prise the plastic that makes up the front, away from the circuit board. Like the back piece, it has a series of clips around the edge, and should lift free without much effort.
  6. Disassembling ZTE Racer II Phone: passo 6, imagem 1 %32 Disassembling ZTE Racer II Phone: passo 6, imagem 2 %32
    • There you have it. Amazingly simple to take apart this phone.
Conclusão
Uma outra pessoa concluiu este guia.
Jacob
Membro desde: 04/27/13
121 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 1,836
