Ir para o conteúdo principal
Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard
O que você precisa
  1. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard, Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: passo 1, imagem 1 %32
    • Insert wisdom here.
  2. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: passo 2, imagem 1 %32
  3. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: passo 3, imagem 1 %32
  4. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: passo 4, imagem 1 %32
  5. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: passo 5, imagem 1 %32
  6. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: passo 6, imagem 1 %32
  7. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: passo 7, imagem 1 %32
  8. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: passo 8, imagem 1 %32
  9. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: passo 9, imagem 1 %32
Conclusão
3 outras pessoas executaram este guia.
Jonathan J
Membro desde: 02/07/14
201 Reputação
Autoria de 1 guia
4 comentários
I tried to open the black part but has cracked with the minimum attempt. Now I have broken the front glass with the black part.
melchorct - Responder
Historia, I cracked black glass (camera). where one can buy ? thanks
kamykazeandy -
same thing happened with me
but at least i was able to open it.
i have unplugged the battery fr long time but still not working, any suggestions???
nimer76 -
Same happened to me with the black camera cover. Do you guys found a replacement?
renehahn - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 7,395
